P2127 Throttle Position Sensor (TPS)
Hello all.
First post here as I sadly can't find any information directly regarding my current issue. Bought a 2005 Saab 9-3 in December. When it's performing correctly I love it, only problem is that it has rarely been performing correctly! This is my latest Saab story: After a long drive in the rain, I woke up the next day and started my car. Engine light immediately came on and she was in limp mode. Read the code and got "P2127 Low Voltage Circuit E". I looked it up and see that this is related to the accelerator pedal. I cleaned the connection from the pedal to the harness and reconnected, no cure. I will be checking more connections tonight and trying to find any shorts. At this point I am refusing to believe the pedal itself is actually defective. The car only has 105k on it, and I can't imagine the pedal giving out. Plus with the rain, unless it is a coincidence, it seems that it must be something in the engine bay. Where I get concerned is that I've found a safety bulletin related to this issue which then led me to some info about a connection in the harness that is particularly weak, but I can't for the life of me find what point of connection is being referred to. I have no other engine codes besides P2127. ----- Has anyone had this issue before? Did it end up being the pedal? Rain involved? Where does circuit "E" go? And why the heck can I still drive it if the TPS is broken?! Strange. Thanks in advance for any help! |
| All times are GMT -5. The time now is 07:18 AM. |
