Saab wont start!
Old May 30, 2013 | 02:47 PM
spyrojohn's Avatar
Default Saab wont start!
Hi everybody,
I would like your advice formy 9-3 saab 2006 model. The engine cranks but it will not start if I leave the engine to cool off. It requires at least 3 efforts while pressing the throttle for the engine to start. If the the engine is hot it starts normally. I will probably go on Saturday to a mechanic but because I have little knowledge about the matter and I do not want to ''be tricked'' I would be grateful if anyone can give me a ''head's up'' for the most probable reason for this problem. Thanks
Old May 31, 2013 | 12:29 PM
sjalks's Avatar
I think your battery's dead
Old May 31, 2013 | 06:24 PM
spyrojohn's Avatar
Thanks for your answer. It might be the battery but the lights and every electric component(cd, speakers, lights) work fine.
Old Jun 16, 2013 | 04:17 PM
spyrojohn's Avatar
Smile problem solved
Hi guys,
I went to a mechanic and he changed the glow plugs and tighten some cables near the fuel rail system. He said that should fix the problem. He said he ckecked start-up motor, di cassette, fpr, cds and all scans were ok. Apparently, the problem remained and every time the engine was cold the crank was long till the cart started. I searched some forums and I found similar problems so I took the initiative to change the battery. The one that it had was 650cca and 2y old. I bought a 780cca one and the problem was solved. I advice anyone that has the same issue to check first the battery.
Bobby
May 22, 2010 07:32 PM
manumart2431
Jun 26, 2009 06:23 PM
ulinda7
Jan 31, 2009 07:58 AM
astark99
Oct 18, 2008 11:37 AM
jpires
Jan 10, 2007 12:28 AM
