-   -   sid traction control/stability control/abs failure (https://saabforums.com/forum/saab-9-3-11/sid-traction-control-stability-control-abs-failure-1256/)
seansaab Oct 15, 2008 02:46 PM
hi people i am only new, i have a late 05 93 vector sport tid 150 bhp
the above problem all popped up in one go today on my sid,does anyone know how this could come about and more importantly am i talking hundreds of £ to get it sorted
many thanks
Roto Oct 15, 2008 04:20 PM
RE: sid traction control/stability control/abs failure
Hard to tell without diagnostics. It could be as simple as a bad ground, or it could be a real problem. Take it to a dealer to get it scanned with a Tech II.
rjsdavis Mar 19, 2013 11:17 AM
Solution: ABS Failure / Traction Control Failure / Stability Control Failure
many thanks
I had this exact issue - whilst driving, one after the other, the three warnings popped up on the SID display and could not be cleared. The first time it happened, when I stopped driving, parked and restarted it cleared it for about 8 minutes - then it happened again. Second time I reset it lasted for ten mins, then happened again. Thereafter, the warning were permanently on as soon as the ignition key was inserted and the key turned.
I called my local Saab specialist who is fantastic and they clearly know these cars inside out. He told me over the phone that the likeliest cause for this was the wiring to one of the speed sensors on one of the rear wheels had become damaged. If it was, would be a twenty minute fix to cut out the corroded wiring and solder in some some new sections.
Was booked in, and the Tech 2 confirmed that the problem was reported with the n/s rear wheel sensor. Sure enough, when the cabling was exposed a section of the bare wire was visible and corroded. Apparently, when the cabling is fitted and then covered in the poly wrap, it is attached to the suspension assembly with a cable-tie and this rubs & wears over time breaking the cable. Just one of those things.
Upon restarting the car, all warnings cleared, no parts required and car fixed - thanks to Motorvation Saab in Tonbridge for once again not fleecing me with my 9-3! £50 - total bill.
