Transmission Gasket and Pan Change
Old Jan 23, 2010 | 06:18 PM
kompasha's Avatar
Question Transmission Gasket and Pan Change
I have 1999 Saab 9-3 SE Convertible. I decided to change transmission oil and gasket. When I went under the car I wasn’t able locate transmission pan. What I saw is two parts of transmission seal together. As well I found out small transmission fluid leak from that junction. Please advice how to change transmission fluid and gasket? Any diagram or instructions are welcome. Thanks in advance.
Old Jan 24, 2010 | 01:20 AM
auto or manual?
Old Jan 24, 2010 | 11:22 AM
kompasha's Avatar
Automatic transmission
Old Jan 25, 2010 | 07:51 AM
Saab Fahrer's Avatar
You won't find a removable pan. Service is simply a drain and refill. Although there is a filter, its only replaced during overhaul, since the case halves have to be split to access it.
Old Feb 2, 2010 | 06:07 PM
kompasha's Avatar
Question Transmission Leak
Thanks to all of you for responds. I see transmission combine from 2 halves. However, the transmission fluid leak is not in this spot. It’s actually more to the right end. There is another transmission “cover” (I am sorry, do not know proper name) which screw to transmission from right by 6-8 bolts. I need to reseal this. However I am afraid to take this part because I don’t know what under. Does anyone know is it safe to unscrew and reseal it?
Please advice. Thanks
parkermoto
1974-1994 900
Sep 28, 2016 11:28 PM
vladdavis
Apr 16, 2015 03:56 PM
mckenzig
1974-1994 900
Jan 3, 2014 01:16 AM
Saturn Simon
1994-1994 900
Feb 18, 2010 10:44 AM
k_nutt
Jun 1, 2009 12:31 PM
