viggen turbo boost?
I have a '01 Viggen and I think the turbo boost gauge doesn't go as high as it used to. It now barely goes into the mid yellow, I thought it used to go into high yellow/low red. the car has 70,000 on it, it had a new pop off valve replaced about 20,000 ago. The car just seems a little slower than it once was. What do you think or know? Thanks
I'm having just about the same thing happen to mine. I have replaced my ignition casset with a brand new one from the Saab Dealer. It helped a little bit, but my boost gauge still doesnt go into red. It gets to the far end of yellow. I checked and rechecked all my vacuum hoses. They are all intact. Air filter is new, No pending dtcs. No corrosion on any electrical terminals. This is a pretty phantom problem. I even had the Service manager of saab re-flash my ecu. still nothing. All intake components are secure and intact. Waste gate is fine, checked it myself. If i pull the 'W' hose off, it will go into overboost, past the red, but then trionic will limit boost until the car is restarted. So i know it is capable of full boost, and that its not a turbo problem. Any direction to go would be great. Plugs have also been replaced with OEM plugs, no aftermarket crap. All Saab Genuine. Needless to say my wallet hates me.
Black9-3
May 25, 2010 10:46 AM
