02' Front-end vibration when hit bumps
Old Sep 29, 2008 | 08:11 AM
jat007's Avatar
Default 02' Front-end vibration when hit bumps
Greetings,
I am new to this forum and first time posting. My 02' drives straight and doesn make any noises. However, I feel this light vibration across the front-end travels up to my steering wheel whenever I hit a big bumps or railroad tracks. My sway-bar end links were bad and I had that replaced and hoping that the vibration would dissapear as well, but it didn't.
The tires are good and has even wear. I haven't had any alignment done or need to at this point. Please keep in mind, the vibration issue only appears when I go over a bump or pot holes.
Please share info and how to remedy this problem if you had this vibration issue before.
Thank you in advance.
Jat
rupenzelleo
Jan 11, 2015 04:32 AM
the blaab
May 20, 2013 04:26 AM
the blaab
Jan 31, 2012 02:06 PM
Dernz3428
Oct 20, 2008 10:59 PM
