2nd start is the charm
I've been having a recent problem with my Saab 9-5. Its a 2002 linear with about 51k on the odometer. When I go to start it for the first time in the morning, it cranks and starts to fire but only runs for about 5 seconds and it is really rough. I then try to start it again and it cranks and runs normally with no problem. It seems like the issue is more pronounced when it has been cool or damp the night before. Any suggestions? Thanks.
RE: 2nd start is the charm
when was the last time you did a full tuneup? Plugs/filters/oil?
I'm planning on replacing the plugs, air filter, and the oil tomorrow.
Couple related questions/updates- I tried to start the car the other day and the first start did as described in my previous post. Try again and the same thing. After the third attempt the car started but I also noted a distinct fuel smell, like the car was flooded. Would this indicate something other than just a tune up. I bought the car used in 2006 and have noticed a reference to a DI recall on the 9-5 model. Could it be that I have a faulty DI and the car never got recalled? Thanks. |
My Friends nissan 04 sentra does that and it happens everytimeI told him as well to change his sparkplugs/oil
,and nothing changed then he took it to the mechanic they said " its perfectly fine" He never looked into it again His Engine catches the first time and then it does the high low Rpm thing twice and shuts off |
try and do the DI recall if it wasn't done... though it's no the symptom of a dying DI it can certainly help.
| All times are GMT -5. The time now is 03:07 AM. |
