-   Saab 900 (https://saabforums.com/forum/saab-900-28/)
-   -   Car won't start (https://saabforums.com/forum/saab-900-28/car-wont-start-1509/)
clifffy Feb 5, 2009 10:13 AM
Car won't start
I drove the car to the store and that's where she sits. I came out and the car turns over fine it fired one cylinder and then nothing. Continued attempts failed.No engine light no signs of trouble.
Any thoughts
Roto Feb 5, 2009 10:16 AM
RE: Car won't start
Year, model and trim please.
clifffy Feb 5, 2009 10:24 AM
RE: Car won't start
1996 900 SE turbo
Roto Feb 5, 2009 10:26 AM
RE: Car won't start
when you get in the car and turn the key in the "ON" position (not trying to start it) do you hear a humming noise from the back of your car?
clifffy Feb 5, 2009 10:28 AM
RE: Car won't start
I dont know I'm not near the car right now would a fuel pump stop the car fromstarting that quick I was thinking possibly the coil pack
Roto Feb 5, 2009 10:31 AM
RE: Car won't start
Yes, a failed fuel pump would do just like that. Happen out of the blue and pretty much no warning. Also if the car starts after it sat for a couple of hours it will most likely be the crank position sensor. It could be the ignition cassette, but I'd check for cold start and fuel first.
clifffy Feb 5, 2009 10:31 AM
RE: Car won't start
It was also rather cold today 6 degrees the car started this morning drove 10 miles no issues
clifffy Feb 5, 2009 10:33 AM
RE: Car won't start
I'll have to get it towed home and check the pump and fuses
Thanks for the advise
clifffy Feb 5, 2009 10:37 AM
RE: Car won't start
Actually I changed the crank position sensor last year
Roto Feb 5, 2009 10:38 AM
RE: Car won't start
Hitting the tank with a rubber mallet from the underneath can sometimes get it to start if it's the fuel pump. If it does start - it's 100% the pump.
