Power Steering Pump
Old Feb 28, 2013 | 04:12 PM
reidg's Avatar
Exclamation Power Steering Pump
Hello,
I've replaced my power steering pump on my 1994 Saab 9000 Turbo..
All is good and my power steering is back, except for inside the resivoir.
There is a geyser inside and it causes the fluid to be airrated..
Is this a problem of an air bubble in the system - and/or has to be bled properly?
I'm not sure of a bleeding procedure..
Anyone have insight?
Thanks
Old Mar 1, 2013 | 06:07 AM
Sounds kind of odd. I ran the system completely dry before and simply filled and it primed itself fine and ran fine. Errr, are you sure your hoses are hooked up correctly? Nothing I can think of in there should be causing a geyser.
Old May 28, 2013 | 09:31 PM
reidg's Avatar
Yeah I only had the inlet and discharge to re-connect
and it's impossible to mix those up..
But yeah it was completley empty too... oh well ill just live with it for now
Thanks Roto
mccarthy69
May 31, 2011 06:45 PM
kl93pitt
Nov 12, 2010 02:15 PM
kl93pitt
Oct 18, 2010 09:11 PM
jheldt17
Aug 5, 2007 01:32 AM
brucecannon
Aug 29, 2006 02:17 PM
