signal failure
Old Jan 11, 2008 | 03:48 PM
mm's Avatar
mm
Default signal failure
I have an 88 convertible. when the signal is on and flashing and you depress the brake the signal goes off. This happens left or right or hazzard. It only stops working when the brake is pressed. any ideas??
Old Jan 11, 2008 | 07:46 PM
Default RE: signal failure
do the brake lights work?
Old Feb 13, 2008 | 07:41 PM
crwchf01's Avatar
Have you made sure the right bulbs are installed? Your failure may be due to the brake light drawing all the power, or check for rub through of the insulation on the back side of the lamp holder. You may be shorting through that to a different ground when the brake is applied
Canada_Saab
Nov 6, 2016 09:36 AM
jlittle900
1974-1994 900
Sep 10, 2016 06:53 PM
kyblusaab
Jan 21, 2011 10:27 PM
blubirdinny
Feb 19, 2010 07:46 PM
johnt365
Nov 24, 2008 11:41 PM
