staying alive
Old Nov 27, 2011 | 12:48 AM
irwin's Avatar
Default staying alive
Hi all, I have a 2000 9-5 2.3 that has 212k miles. I have the car for 4 years after buying it at 124k. It has been good to me, at least compared to the horror stories out there. I have done most of the maintenance myself, such as suspension,brakes,exhaust, fuel system, electrical issues and other minor work. I recently put in the pcv upgrade. The oil pan and cam area had no sludge, just a bit of varnish. The car is still on its original alternator and starter. Has not had a tranny or engine rebuild. I would appreciate any and all advice on how to get another several years out of this angel. Should i put in a new timing chain and gear set? Would new oil pump gears be a prudent measure? As of now, the car still has plenty of pep. Compression readings on each cylinder is around 150 psi. Thanks for your help.
mattcadwalader
Dec 31, 2020 07:26 PM
mclovinfe
May 14, 2012 09:57 AM
AllanR
Nov 8, 2010 06:39 PM
saab03
Sep 21, 2008 10:42 PM
saab03
Sep 17, 2008 05:39 PM
