check gear box light
Old Jul 31, 2008 | 08:01 PM
cayman robb's Avatar
Default check gear box light
Hi all,
Need help, anyone had similar problem. Check gear box light on, will not down shift. Turn ignition off and it reset itself, but drive for a few miles and the check light come on again. Stuck in high gear.
Regards Robb
Old Aug 16, 2008 | 11:20 AM
llurkin's Avatar
Default RE: check gear box light
The neutral safety switch is located on top of the transmission, underneath the battery on a 1995 saab. It may be the same on yours.
Over time, the lubrication used builds a "ramp" and the contact points do not connect, so the check gearbox light comes on, and the car goes into fail safe mode.
Either replace the switch, or, if you are adventuresome, remove the switch (about 1 hour in your driveway) take the switch apart, straighten out the lubrication, and reinstall.
I did mine 2 years ago, and haven't had a problem re-occur.
Good luck.
Old Jan 4, 2009 | 09:11 AM
andrew65's Avatar
gear box hey guys can we change the gear[/b] box[/b]...and can we fit the pulsar gear[/b] box[/b] i.e 5-speed gear[/b] box[/b] for this one? [/align]
scania19
1994-1994 900
13
Jul 28, 2021 01:39 PM
Canada_Saab
Nov 6, 2016 09:36 AM
parkermoto
1974-1994 900
Sep 28, 2016 11:28 PM
ThePoisonDonut
Sep 22, 2016 07:49 AM
jryankelly
Jun 20, 2012 07:01 PM
