Interior Fan Stopped Working
Old Mar 24, 2006 | 12:23 AM
JettaRed's Avatar
Default Interior Fan Stopped Working
I have a 2000 9-5 Aero and the interior ventilation fan just stopped. The fan speed adjustment seems to work, but the fan doesn't blow. I check fuses. Is there a relay too? Any ideas? TIA
Old Mar 28, 2006 | 02:33 PM
Patrick's Avatar
Default RE: Interior Fan Stopped Working
best case scenario woudl be a bad switch, as that is probably the least expensive to fix...
Old Feb 20, 2007 | 10:38 PM
For future reference: IF the fan made any noises before quitting it is most likely the blower motor.
Old Feb 27, 2007 | 09:46 PM
jmchilljack's Avatar
you might want to find a repair chart i have seen a lot of blower modules go bad there on the right side of the heater box about a 1 1/2 square box just behind the console front panel
Old Feb 27, 2007 | 10:13 PM
Do you mean the blower resistor or the relay?
Old Jul 11, 2009 | 10:55 AM
madisongulf's Avatar
I ran into the same problem recently - middle of winter. Heat but no fan. Now with the hot weather finally coming to NH I need the blower for AC. Did you locate the problem/solution?
Thank you.
Canada_Saab
Nov 6, 2016 09:36 AM
Susanna Conway
Oct 23, 2016 03:46 PM
Madstyle00
Jul 14, 2009 08:53 PM
Andrew
Nov 11, 2008 09:16 PM
ernieguevara
Nov 10, 2008 12:32 PM
