power window problems
Old Feb 28, 2009 | 01:53 PM
saab900's Avatar
Default power window problems
Hi all im new to this site and new to saabs i recently pursched a 92 saab 900 turbo convertable and im having some problems with the driver power window when you turn the ignition on the window rolls down. also the top dose not work to lower the to you have to do it manually. ive checked all the fuses and relays for the top and the windows. any help will be greatly appricated.
thanks
matt
Old Mar 1, 2009 | 09:18 AM
boostpowered's Avatar
broken switches?short in wiring
Old Mar 1, 2009 | 09:48 AM
saab900's Avatar
ive checked the wiring its all good ive also checked the switch and it tested good but its the master switch for the widows and i believe its a problem in the master switch just wanted a second opinion on it or if someone else has run in to the same problem and the top i figured out already.
thanks
Old Mar 4, 2009 | 12:59 PM
check your ground if the switch tested good and you have power to the switch
and no rotten/cracked wires then you probably dont have a good ground
Old Mar 4, 2009 | 07:56 PM
saab900's Avatar
ok thanks ill check that next time i work on it.
Old Mar 20, 2009 | 10:56 PM
gatr2000's Avatar
i now have 3 out of 4 windows not working.. today my driver side window ..i roll it up and here this loud snap..i thought the window cracked...the motors on these windows are too strong for the cheap aluminum brackets...the motors should cut off once closed ..three out of 4 windows proves that wrong.
Old Mar 21, 2009 | 09:38 AM
gatr 2000 replace those mounts with solid grade 8 bolts and locknuts the play in the mounts causes the cable to bind and it either snaps the cable or burns the motor up
wayne2074
Mar 23, 2021 03:55 PM
rickyl2
Jan 10, 2011 11:36 AM
fox
Jan 25, 2007 12:04 AM
Brooklynisis
Dec 7, 2006 03:17 PM
JohnnyC
Nov 10, 2005 05:57 PM
