Is it ok to take my Saab to a standard oil change?
Old Jun 17, 2010 | 04:52 PM
tiodecember's Avatar
Default Is it ok to take my Saab to a standard oil change?
I have a 2000 Saab 9-3 with 91k miles. I have been taking it to the Saab dealer every 2800 miles and paying $120.00 to have the oil changed. What is the difference between this oil change and a standard oil change that costs half as much?
Old Jun 17, 2010 | 11:30 PM
45guy's Avatar
I switched to the DIY home method 2 changes ago and cut the price by over 50%.
I'll grant that a conscientious dealer will take a look around while it's on the lift but if an oil change is all you're after, do it yourself.
And use synthetic oil.
Old Jun 18, 2010 | 03:58 PM
westo1mj's Avatar
If you're using synthetic oil, then you are changing your oil way to much anyways. For an older model with say synthetic, you should be able to push at least 5,000 miles with no problems depending on driving conditions.
Old Jun 19, 2010 | 05:32 AM
Default Re: Westo
Wow, what great advice, change the oil less frequently. 10 year old Saabs always do well when you stretch out maintenence and dont follow the owner's manual.
Old Jun 30, 2010 | 10:25 AM
luvSaab28's Avatar
it's not as good quality of oil is my guess
Old Jun 30, 2010 | 02:29 PM
frank301162's Avatar
my saab is 11yrs old, i still use synthetic oil, especially when i have just rplaced the turbo, i am in the trade so the oil isnt as expensive, oh i forgot she has 140000 on the clock
diabolicus
Dec 9, 2011 03:02 PM
Nate
Apr 2, 2011 07:22 PM
tri18
Oct 8, 2008 12:26 PM
simonbiddle
Dec 8, 2005 01:48 PM
