manual trans question
Old Mar 27, 2007 | 03:03 PM
mrJones's Avatar
Default manual trans question
Hello all, I have an 07 9-3 2.0T (6 spd manual trans)and my question is: when I start to pull forward from a parked position, the clutch seems to "click". It really makes no sound, but you can feel it under your foot. It really is barely noticeable.It feels like something is disengaging. I do not feel this when driving, or when shifting from 1st upwards(from a dead stop), only the first time I pull out. If this makes sense, is this normal? Am I crazy?
Old Sep 4, 2007 | 08:27 PM
kurtdaniel's Avatar
Default RE: manual trans question
Clutch chatter, a vibration and/or noise when engaging the clutch, is likely to be caused by an internal clutch problem. A warped disc, hotspots on the flywheel or pressure plate surfaces, worn or dry input shaft splines, or worn release bearing..this may help http://www.clutchwizard.com/diagnosis.htm saab cutch. best of luck
volvosaabtech1983
Nov 3, 2011 10:00 AM
js123
6
Aug 23, 2011 12:47 AM
dougo01
May 7, 2011 05:32 PM
hoodoshnik
Jul 17, 2006 09:25 PM
madisonsaab
Dec 1, 2005 03:55 PM
