Headlight and rear window washers not working
Old Dec 19, 2007 | 10:32 AM
Mikro's Avatar
Default Headlight and rear window washers not working
Both washers for ste headlights and rear window washers have stopped working again.I've had this repaired twice in a year.I can hear the pump for the rear window.Is there a way to fix this myself?
This is for a 1999 9-5 wagon
Thanks...
Old Dec 19, 2007 | 03:17 PM
Default RE: Headlight and rear window washers not working
The check valves are the problem. I fixed my by simply replacing the stupid things with vaccum 'T' and 'L'fittings and all has worked fine ever since.
Old Dec 25, 2007 | 10:24 AM
Mikro's Avatar
Thanks for the reply Roto.
How do I get to these valves and where would I get the fittings?
Old Dec 25, 2007 | 10:31 AM
You'll find them in the rubber lines going to the washers. Take a look at the ones in your hood where the windshield nozzles are and look for similar plastic pieces. The fitting you can get at any local auto store. Don't expect this to be easy as some of these stupid check valves are in tight spaces...
sheather17
Nov 17, 2009 07:46 AM
Mountain man
Aug 1, 2009 04:55 PM
Onassis91
Jul 20, 2009 01:14 PM
92_9000s
Nov 2, 2007 09:11 PM
gtoft
Aug 9, 2007 04:52 PM
