fuel pump
Old Feb 5, 2009 | 12:45 PM
clifffy's Avatar
Default fuel pump
looks like I may need to replace my fuel pump on a 1996 saab 900se anyone ever change one tricks of the traded expected roadblocks etc. Do I need to change the whole module or can I just replace the pump??
Old Feb 5, 2009 | 01:31 PM
boostpowered's Avatar
Default RE: fuel pump
the pump alone will be about 115.00-130.00 the whole assembly is anywhere from 310.00-507.00 be prepared for bloody knuckles
FUEL PUMP REMOVAL
[93 98-03, 900 94-98]
Removal Instructions:
STEP1
Work in a well ventilated order due to fuel fumes & wear gloves due to fuel chemicals
STEP2
Saab recommends having a fire extinguisher handy as well.
STEP3
Remove the Fuel Tank and remove the screw top that holds the fuel pump in. There is a special tool from Saab (8394462). Many will use two screwdrivers to unscrew the top counterclockwise.
STEP4
Once the fuel pump top is removed lift up the pump about 2 inches and then turn the pump about 90 degrees clockwise and pull it the rest of the way out.
STEP5
Fit a new Oaring and realign the pump with the alignment mark on the pump and the tank. Reinstall Top and torque to app. 55 ft-lb.
STEP6
Reinstall Tank.[align=center][/align][align=center][/align][align=center][/align][align=center][/align][align=center][/align][align=center][/align][align=center][/align][align=center][/align][align=center][/align]
Old Feb 5, 2009 | 01:36 PM
There's also a way to do it without dropping the tank, but I'm hesitant to suggest it.
Old Feb 5, 2009 | 01:42 PM
do the 900 have the little door behind the rear seat under the trunk floor?is that the other method
Old Feb 5, 2009 | 01:54 PM
The other method is making that little door under the rear seat. I believe nbsman just did it a week ago and it seemed to have worked well.
Old Feb 5, 2009 | 02:04 PM
so you would have to cut it out on the 900 ha 9000 comes with that door
Old Feb 5, 2009 | 02:42 PM
Well technically there is a door on some of them, BUT it's in the completely wrong place.
Old Feb 5, 2009 | 02:55 PM
weird
Old Feb 7, 2009 | 10:19 AM
clifffy's Avatar
Thanks Guys I looked for the access hole only to find it only gives access to the electrical connections. I put a meter on teh power to the pump and found no power when teh key is in the run position the fuse is good. Does this car have a pressure switch that could be affecting teh pump.
I will be making a hole to get to the pump without dropping the tank. I'll let you know how it goes.
Old Feb 7, 2009 | 12:53 PM
if you have no power to the pump I would investigate that first. Reset the ecu by disconnecting the battery and try to measure again.
delekay
Mar 18, 2013 12:41 PM
Sambog
Nov 21, 2011 07:58 PM
Zeecar
1974-1994 900
9
Jul 24, 2010 06:05 AM
Gordo
Jan 7, 2009 08:35 PM
LEOCANCIO
1974-1994 900
Aug 7, 2008 06:33 AM
