Steering not centering
Old Sep 14, 2008 | 02:06 PM
chefyong's Avatar
Default Steering not centering
I noticed that the steering wheel after making a turn does not center right away. You need to assist the steering to center up. Checked power steering fluid and belt, both are okay. Any ideas?
Thanks
'92 Saab 16v Turbo
Old Dec 22, 2008 | 08:48 AM
boostpowered's Avatar
Default RE: Steering not centering
check rod ends both inner and outer check ball joints and controll arm bushings many things can cause steering and drivability problems if the rod ends are bad and you continue to drive with this issue it can cause wheel bearings to go bad
cjharris02892
Nov 14, 2015 03:48 PM
gmwarranty
Feb 26, 2011 06:21 PM
Thora
Jul 13, 2010 11:42 PM
Roto
Jun 11, 2009 10:40 PM
jheldt17
Aug 5, 2007 01:32 AM
