Exterior Talk about your rims, body kits, and other exterior mods here.
the lamp powering rated voltage 220V
Old May 1, 2011 | 08:26 PM
okh390p4n's Avatar
Banned
Default the lamp powering rated voltage 220V
LexanDMX resin together with H-class pen hardness, exterior hardness will be 2. 5 times standard PC, but zero special coating to achieve excellent damage resistance. Any time exposed to be able to ammonia. LexanDMX resin can maintain its transparency, exterior finish, and scalability to make certain the lights still maintain an excellent appearance, light transmission is usually efficient and also avoid raise the risk of brittle fracture which might result. Included in Luzern flashlights, SABIC Progressive Plastics supplies transparent materials like water out of your growth esophagus was used as a shell LED lamp. Lexan DMX copolymer different possible uses include digital products, controls and feel screens, tv sets along with notebook shape, lens, movie and scratch-resistant blend sheet. K show in 2010, SABIC Ground breaking Plastics will still enrich this LED showcase industry resources solutions.for the world, Luzern38LED flashlights and different applications could demonstrate the commitment involving Norka for the LED marketplace. STARK along with TALEXXengine FULMEN LED light method is highly developed with the Austrian distinct, it features a very prime quality optical feedback and white,LED neon sign, and will be best option for downlights along with spotlights. White lighting quality along with light end product advances mean that light-emitting diode LED would work for unique occasions from the product developed suitable universal easy source, for that reason, LED lower light and also spot lights is usually used while. Sharply higher in 2010 in the lighting plus building screen exhibition TALEXX products is perfect for these job applications LED alternatives. TALEXXengine STARK is for stores, corridors as well as rooms developed in downlights, with energy proficiency, LED is an ideal different than compact fluorescent method.Test Technique 1: the lamp powering rated voltage 220V, allowed to figure, start operating down any time until every single lamp is usually damaged, note any time of end of contract, when every one of the lights personal injuries, find usual working time frame of light Here is the life of the product. Test out Method ONLY TWO: based for the actual light products, to look at the life from the aging accelerated methods (such while adding high-temperature, questionable and regular switching, and many others. ), in line with the real situation from the aging making special tools. G: aging test. Brand new products into production, you should, respectively, in the number of trial creation, and as a result of small-batch demo production cycle in volume, through the design of these tests can identify problems just like non-raw substance and process issues. Information specific analyze method. Primary testing gear: the aging units, voltage regulator,restaurant board, voltage meter. Primary test things: Batch development of natural materials. The number of tests: 400 small weighing machine, pilot 2000.Test out methods; primary raised the voltage 250V, disappointment the electricity,LED message board, then the actual aging platform product fitted, the switch 3 times, each time period interval with 8 a few moments, then away from, then voltage to help 170V, electric power observation, the past tune the voltage for you to 250V, 2 hours following aging, the switch 3 times at times of 8-10 seconds, the completed of growing older. In this above examining process problems are only substandard goods, in have to have of restoration.:With this growing number of tunnel initiatives, tunnel engineering in present day transportation enjoy an increasingly important role. Tunnel can be a closed area, natural light is unable to light them,vinyl banner, in order to ensure the continuity with driving as well as vehicle basic safety of human being life, even in the daytime throughout this internal will need of unnatural lighting, tunnel lighting effects is an inclusive piece of the tunnel construction. Chips applying silicon carbide substrates for that L-type electrodes, two electrodes positioned in the floor and bottom with the device, the heating generated is usually exported over the electrode; one time that this substrate does not require conductive coating, and therefore will not be current picture diffusion coating of material absorption, which also boost the light removal efficiency.
trebor
Jun 20, 2012 02:23 PM
techmerlin
Aug 8, 2011 06:35 AM
Meinhaj Hussain
Aug 6, 2007 12:14 PM
Sparkplugs.com
Dec 1, 2006 04:53 PM
SaabRX
Oct 17, 2005 03:42 PM
