oil drain plug stripped
Old Dec 5, 2005 | 06:05 PM
neward's Avatar
Default oil drain plug stripped
94 900SE Turbo
I've own the car since September. I was going to change the oil for the first time (and a few hundred miles overdue) when I find the plug is stuck. The Oil Drain Plug is now stripped beyond all recognition. I took it to a muffler place in order to get a new flex pipe made for the exhaust behind the cat. converter and they too tried and failed to get it off.
I called a dealer to see if they have an oil pan and gasket in stock. They didn't and it would be $327 if they did. He recommended taking off the pan and trying to get the plug out then.
Does anyone else have any ideas/comments/suggestions?
Old Dec 8, 2005 | 01:40 PM
Patrick's Avatar
Default RE: oil drain plug stripped
so the pan itself is stripped? they make something that screws into the hole, and sort of taps itself in. in that piece, is a smaller drain plug..this is sort of a ghetto fix, but i have seen LOTS of it, and it works..it just takes longer to drain the oil.
mrknitefall50
Apr 4, 2023 08:26 AM
parkermoto
1974-1994 900
Sep 28, 2016 11:28 PM
Komet
Jan 14, 2016 11:54 AM
Alcharger
Feb 16, 2009 09:05 AM
bojib
Mar 26, 2008 06:57 PM
