power window problems
Hi all im new to this site and new to saabs i recently pursched a 92 saab 900 turbo convertable and im having some problems with the driver power window when you turn the ignition on the window rolls down. also the top dose not work to lower the to you have to do it manually. ive checked all the fuses and relays for the top and the windows. any help will be greatly appricated.
thanks
matt
thanks
matt
ive checked the wiring its all good ive also checked the switch and it tested good but its the master switch for the widows and i believe its a problem in the master switch just wanted a second opinion on it or if someone else has run in to the same problem and the top i figured out already.
thanks
thanks
i now have 3 out of 4 windows not working.. today my driver side window ..i roll it up and here this loud snap..i thought the window cracked...the motors on these windows are too strong for the cheap aluminum brackets...the motors should cut off once closed ..three out of 4 windows proves that wrong.
Brooklynisis
Dec 7, 2006 03:17 PM
