saab 900 wont turn over
Old Mar 18, 2015 | 05:16 PM
jackraider's Avatar
Default saab 900 wont turn over
I have a problem starting my 900. I turn the key and can hear the relay activate but the starter doesn't turn over. I have changed the starter, it still had the same problem temporarily but then turned over and ran fine for about 4 days, now it wont start again. I have checked the battery (it has 12.7 volts idle and 12.2-12.3 volts once the key is turned) and the terminals. I have also checked that I have power going into the starter on the main loom which it has (12.2-12.3 volts) Is there a common fault on the electrics circuit somewhere that could cause this or any other ideas would be appreciated.
Old Aug 27, 2015 | 12:49 PM
CarPartsDiscount.com's Avatar
Former Sponsor
I realize that this is an older issue and you probably have it solved by now but this sounds like a starter solenoid, when you swapped your started did it come with a new solenoid?
here is a link to some starters that we offer with new solenoids
https://www.carpartsdiscount.com/sta...html?3594=1025
Bpeirson
Feb 16, 2015 04:16 AM
SaabRocks
Jan 12, 2011 10:57 AM
ulinda7
Jan 28, 2009 11:01 PM
bwainwri
Jan 20, 2009 02:26 PM
cblack0127
Jul 6, 2006 02:36 AM
