Off Topic A place to boldly go off topic... almost anything goes.
9-3 Front Amplifier Fuse, F25
Old Mar 16, 2015 | 07:26 PM
jrobinson47's Avatar
Default 9-3 Front Amplifier Fuse, F25
My car (2006 9-3 2.0T) won't set more than a day before the battery is dead, this is with the theft alarm disabled. With ignition in OFF, I am seeing .33 amps in this fuse socket. Seems too high to me. What does this fuse supply?
Old Mar 16, 2015 | 07:58 PM
Default Further Info on F25
Looking further, this appears to be for the Bose front speaker audio amp. I looked for where service manual says it should be, (rear of driver's side wheel well, I see only the bracket on the floor, no AMP. I removed F25, no codes or warnings, audio system works as before.
This is a base 9-3, is it supposed to have this AMP?
Also, this car has not had any audio out of the front door speakers (both sides) since I purchased in Sept 2014.
Am I on to something?
For now, I am leaving this F25 OUT.
Old Mar 16, 2015 | 08:10 PM
Default 9-3 f25
FYI, I also found no unterminated electrical connectors in the area of the amplifier.
info2
May 14, 2013 07:16 AM
delekay
Mar 18, 2013 12:41 PM
lluisgi
Aug 19, 2012 05:27 AM
denny09
Feb 7, 2011 06:29 AM
Nicola
Aug 24, 2010 05:20 PM
