Check engine light
Old Apr 16, 2021 | 04:50 AM
Hallon's Avatar
Default Check engine light
I have a 2003 Saab 9-3 1,8t where the check engine light is dead. I was in for the annual test and the car has thrown a p0420 fault which should trigger the check engine light. The check engine light does not even come on when I turn on the ignition. For the earlier generation 9-3 it seems you can change bulbs in the instrument panel but not sure if that's the case in the -03 and onwards. Anyone heard of similar issue? A bit ironic as all forums and youtube clips are about how to turn the check engine light OFF where I actually want mine to come ON ;-)
Lief
Jul 13, 2018 05:53 AM
zell66
1994-1994 900
Jul 15, 2016 07:08 AM
jhan
Nov 10, 2012 12:42 PM
johnqpr
Jan 17, 2012 01:00 PM
tony
Aug 9, 2010 10:49 AM
