Gas Cap Vented or NON-vented??
Old Aug 8, 2008 | 07:51 PM
whiplash's Avatar
Default Gas Cap Vented or NON-vented??
I found older SAAB 900 in U-pullit and the gas cap was non-vented. Will this work on a 2000 9-3? I also got the headlights and wiperset-up. Mine were broke -lights were pitted up- Junk ones looked great compared. My engine light comes on and off due to vac leak.
Old Aug 9, 2008 | 01:24 AM
xhawksaab's Avatar
Default RE: Gas Cap Vented or NON-vented??
The gas cap in your 2000 9-3 in NON-vented. The vac leak MAY be due to a bad gas cap seal. Are you getting code P0455? The other possibilities are bad vacuum hoses and a malfunctioning EVAP purge valve.
Old Aug 9, 2008 | 07:29 PM
whiplash's Avatar
Thanks. I have replaced cap but light stays on. I will have to get code read again..
Old Aug 9, 2008 | 09:32 PM
try resetting the ecu first...pull the negative battery cable off for a few minutes. See if CEL reappears.
