mad series of events
Old May 1, 2006 | 10:13 AM
xsoooby's Avatar
Default mad series of events
hi newbie here i need your expert help i own a 98 93 convertible and what started as something simple started like this
left the ignition on for half an hour tried starting it and battery nearly dead so as i am on a hill i let it roll to bump start it in second gear nothing pull it out of gear and atempt to put it into first gear car crunches badly then hell lets loose
1) no gearchange
2) no clutch
3) no brakes
4) hydraulic fluid coming out from under the car
madness but once i have calmed down i check under the bonnet find a app. 4" round thing around the gearlinkage which i realise is the rear engine-geabox mount it has shattered braking a plastic gear linkage a brake pipe or what i think is and a clutch hydraulic pipe
so the thing is what is the proceadure with replacing the mount and i cant see but is the brake hydraulics connected to the clutch hydraulics as i cant seeat the moment if just one pipe is broken or two
Immo
Apr 23, 2009 05:56 AM
Saab2b
Feb 15, 2008 06:14 AM
