Power window Switch
I found out the other day when I took the car to a local Saab mechanic that sells Saab's on the side, that the power switch for the driver's side does not let the window power "up". I would prefer to buy one off of Ebay for 30 to 90 dollars and replace the module. Like a nuckle head, I left the Saab with the repair shop and I have no access to it until next Friday when I return from work. I did not get a chance to look at the switch, but the mechanic pulled a switch from a 4 door Saab and briefly changed out the switch tosee if it was the issue, which it was. So, can the indiviual console switches for each function be accessed by removing thepower switchand taking it apart? If so, then it is not such torment to buy a switch off of Ebay and replace an individual switch than the whole unit. Otherwise it is a shooting match to buy a unit on Ebay that will just"swap out" the power switch.[sm=pcwhack.gif]
skyhawk85u
Nov 4, 2007 07:59 AM
eisenb11
Oct 17, 2007 08:49 PM
