LED point light dotted facade
Old Mar 31, 2011 | 09:05 PM
okh390p4n's Avatar
Banned
Default LED point light dotted facade
Sapphire substrate has many advantages: First, the sapphire substrate production technology is mature, good quality components; Secondly, the stability of sapphire good to use in high-temperature growth process; Finally, the sapphire of high mechanical strength, easy to handle and cleaning. Therefore, most processes are generally on sapphire as a substrate. Figure 1 Example of the use made of sapphire LED chip. Use of sapphire as a substrate, there are some problems, such as lattice mismatch and thermal mismatch stress, which will generate a large number of defects in epitaxial layer, while the device for subsequent processing difficult. Sapphire is an insulator, the resistivity at room temperature is greater than 1011Ω?; Cm, in which case the vertical structure of the device can not be produced; usually produced in the epitaxial layer on the surface of n-and p-type electrode (as shown in Figure 1 shown). In the production of two electrodes on the surface, resulting in a reduction of the effective emitting area, while increasing the device fabrication process of photolithography and etching process, resulting in lower material utilization, the cost increase. Since P-type GaN doping difficulties,LED billboard, the current widely used in the preparation of p-GaN metal transparent electrodes on the ways in which current spread, in order to achieve the purpose of uniform light. But the metal transparent electrode generally absorb about 30% to 40% of the light,LED sign, while the chemical properties of GaN-based materials stability, high mechanical strength, its not easy to etch,LED message board, so the etching process of the need for better equipment,electric signs,
techmerlin
Aug 8, 2011 06:35 AM
45guy
May 1, 2011 02:06 PM
snaab9
Sep 29, 2007 11:34 PM
Sparkplugs.com
Dec 1, 2006 04:53 PM
SaabRims
Jul 12, 2006 01:21 PM
