Power locks are dead
Old Nov 25, 2009 | 09:28 AM
ataie's Avatar
Default Power locks are dead
my power locks are not working. nothing happens when pushing the lock/unlock botton in the center. no noise or clicking, anything. currently I have to lock each door manually. I also had to reorder a key, so have to program my keyless as well.
anyone with any suggestions beside going to dealer?
thanks,
04 9-5 sedan
Old Dec 2, 2009 | 09:31 AM
ataie's Avatar
Originally Posted by alamlics73
Does anyone no what was the first year and model Datsun/Nissan Trucks had power windows & door locks?
dude, are you for real? this is a saab forum, and you hijack my thread to ask about a freakin datsun??? try googling datsun forum, it'll be more helpful than asking here, as we're having a hard time getting answers to saab questions.
Old Dec 4, 2009 | 09:50 AM
First thing to check is whether the actual switch works. That's easily done with a multimeter. If it does - check if there is power getting to the switch.
Old Dec 4, 2009 | 10:19 AM
ataie's Avatar
yes, there is power to the switch. all fuses are good as well. even with bad center switch, the power lock should work by locking/unlocking driver's side lock using a key, and that doesn't do anything neither.
is there a power lock module somewhere that I can check? thanks
Old Dec 4, 2009 | 10:40 AM
The locks are tied into the TWICE module (read - expensive), When you open the door you can get access to the wires going into the door to the lock solenoids (rubber hose thing in the jamb). Check to see if you have power to the locks. If you don't - TWICE is the most likely cause of this.
justinbowen
Feb 9, 2015 08:32 PM
argoolsbee
Jan 21, 2011 08:59 PM
hellodon
Aug 1, 2009 04:52 PM
ernieguevara
Nov 10, 2008 12:32 PM
trans100
Oct 19, 2008 07:35 PM
