wiper washer
Old Dec 18, 2008 | 11:08 AM
cajunsally's Avatar
Default wiper washer
My wipers work but the washer won't spray. no noise from the washer pump either.
Also, dome light does not light when door is open.
Radio antenna motor disconnected by previous owner because it was oscillating up and down.
Any Help or suggestions appreciated.
Kevin
Old Dec 18, 2008 | 03:47 PM
Default RE: wiper washer
Get to the washer motor and test it...if it works than something is fried in the circuit. Did you try replacing the bulb in the dome light? Are you sure there is a problem with the antenna? Did you see that oscilation yourself?
Old Jan 4, 2009 | 09:03 AM
andrew65's Avatar
I have a windsheild washer[/b] on front,like many of our frens.Can any 1 suggest a good fluid to me.How 2 use it ? is it to be mixed wid water ? n whr will i get it.
Presently its useful having one in dusty dry conditions of this season.But am using plain water .Will mixing a lil bit of surf! cause problems? to the motor spray etc.?
Susanna Conway
Oct 23, 2016 03:46 PM
Patrick Prince
Aug 18, 2016 03:31 PM
Thebutcher
Jul 6, 2011 12:51 PM
denny09
Feb 7, 2011 06:29 AM
Autogeek
Jan 15, 2008 08:47 AM
