'03 9-3 Recirc Valve Hose Removal?
Old Oct 4, 2008 | 07:56 PM
presto123's Avatar
Default '03 9-3 Recirc Valve Hose Removal?
Hi,
I was just wondering if this was a feasible thing to do with these "newer" engines. Someone emailed me in response to their own car, a '99 9-3 that this is what they did with theirs. I liked the sound of his turbo venting off and would like to do this as long as it does ABSOLUTELY NO damage.
If it does not, which one is it? I found the one that is looped from the top of the valve back into the system, but it's also connected to some of the electronics.
Anyone with an '03 9-3 done this?
Thanks,
Presto123
Old Oct 5, 2008 | 11:00 AM
Default RE: '03 9-3 Recirc Valve Hose Removal?
if you do this you will get a check engine light. 1999's were the last year equpped with a MAP sensor and that's why it was harmless there. On a MAF sensor car it throws a CEL.
Old Oct 5, 2008 | 11:31 AM
presto123's Avatar
Ah, okay. Thanks. Looks like you can do LITTLE easy modifications with this car.
I love the thing, but even the lights are a pain to replace.
Old Oct 5, 2008 | 04:11 PM
Don't be quick to judge. They still are easy to modify, you just need the right approach and a definite plan of what you want the car to look like in the end.
Autogeek
Aug 10, 2019 09:34 PM
info2
May 14, 2013 07:16 AM
stirfriedsushi
Nov 7, 2011 04:51 PM
AllanR
Nov 8, 2010 06:39 PM
ed1le
Oct 3, 2005 09:31 PM
