Speed Compensated Volume
Old Jun 2, 2008 | 11:49 PM
staffmonkey's Avatar
Default Speed Compensated Volume
I wanted to set up the Speed Compensated Volume, following the manual directions to hold the BAND button while turning on the stereo. When I did this, my radio started cycling through each speaker, first the tweeters in one cycle then the bass. This continues until I shut the stereo off.
I never saw any options on the SID.
Any suggestions on what I'm doing wrong? I'm really confused.
(It's an '02 9-3 SE)
Thanks
Old Jun 4, 2008 | 06:08 PM
Default RE: Speed Compensated Volume
Problem solved.&nbsp\\; I discovered a discrepancy in the manual and an easter egg of sorts.&nbsp\\; The directions say to push the power and "Band" buttons at the same time.&nbsp\\; In the American version, the "Band" button should actually be "WB".&nbsp\\; If you hit the "Band" button (as it's labelled on the radio), you'll engage a test function that runs through each component of the speakers (tweeter, woofer, etc).&nbsp\\; Useful if you ever suspect a bad speaker.
Canada_Saab
Nov 6, 2016 09:36 AM
Susanna Conway
Oct 23, 2016 03:46 PM
Juan Vite
Oct 15, 2016 08:54 PM
Saabertooth
May 8, 2014 07:04 PM
glfpimp
Aug 29, 2005 03:10 PM
