Car won't start
Old Feb 5, 2009 | 10:13 AM
clifffy's Avatar
Default Car won't start
I drove the car to the store and that's where she sits. I came out and the car turns over fine it fired one cylinder and then nothing. Continued attempts failed.No engine light no signs of trouble.
Any thoughts
Old Feb 5, 2009 | 10:16 AM
Default RE: Car won't start
Year, model and trim please.
Old Feb 5, 2009 | 10:24 AM
clifffy's Avatar
1996 900 SE turbo
Old Feb 5, 2009 | 10:26 AM
when you get in the car and turn the key in the "ON" position (not trying to start it) do you hear a humming noise from the back of your car?
Old Feb 5, 2009 | 10:28 AM
clifffy's Avatar
I dont know I'm not near the car right now would a fuel pump stop the car fromstarting that quick I was thinking possibly the coil pack
Old Feb 5, 2009 | 10:31 AM
clifffy's Avatar
It was also rather cold today 6 degrees the car started this morning drove 10 miles no issues
Yes, a failed fuel pump would do just like that. Happen out of the blue and pretty much no warning. Also if the car starts after it sat for a couple of hours it will most likely be the crank position sensor. It could be the ignition cassette, but I'd check for cold start and fuel first.
Old Feb 5, 2009 | 10:33 AM
clifffy's Avatar
I'll have to get it towed home and check the pump and fuses
Thanks for the advise
Old Feb 5, 2009 | 10:37 AM
clifffy's Avatar
Actually I changed the crank position sensor last year
Old Feb 5, 2009 | 10:38 AM
Hitting the tank with a rubber mallet from the underneath can sometimes get it to start if it's the fuel pump. If it does start - it's 100% the pump.
mwatson111
Oct 17, 2007 09:34 PM
ode
Aug 18, 2007 11:21 AM
Stripercrazed
Jun 25, 2007 08:47 PM
sparkin5280
Jul 6, 2006 03:31 PM
sparkin5280
Jun 16, 2006 03:59 PM
