93 2.0 1998 liter petrol starting problem
Old Jul 12, 2013 | 07:43 AM
PereCarrizo's Avatar
Default 93 2.0 1998 liter petrol starting problem
Hello
I hope someone here with experience with this car has a suggestion.
The car was unused for 2 months, after which it was difficult to start (cranking several times). My mechanic put in an injection cleaner and seemed to improve it a bit, but then, after about 100 miles, all of a sudden it wouldn't start at all. It took many cranks and then started. it now takes a couple more times than usual to start, but it starts. Though, I'm afraid the same thing will happen again and drain the battery.
Any suggestions. I have seen here it could be the crank position sensor, but not sure these are the symptoms.
Thanks very much for any advice, it's a shame to ditch such a good car with 120.000 miles because of this (it only cost 1000 pounds. 1300 euro).
Pedro
Old Jul 23, 2013 | 10:45 PM
ChrisPerkins's Avatar
any check engine light? possible that it is the fuel pressure regulator, try cycling the key 2-3 times with out actually starting it then give her a whirl. fuel pump still going strong??? fuel filter, air filter, good battery good starter? compression checked? is it in spec? sat for 2 months could be ****ty gas, draining old gas and filling with new premium fuel
wayne1
18
May 12, 2015 01:44 PM
stirfriedsushi
Nov 7, 2011 04:51 PM
jan
May 17, 2011 08:28 PM
wayne1
Sep 4, 2006 09:22 PM
ken2830
Jan 28, 2006 06:12 PM
